Yes.Is it ok to go with the pressure vessel on the Rad Circuit?
Dunno - do they work?Shall I change all the CH pipes (£550) to do so?
Vaillant if those are the only options you want to consider.Shall I go for the Baxi or Vallaint boiler (vallaint will cost around 200 extra)
Cylinder size will make naff all difference.With 9 rads and a 160ltr tank I was specced a 18kw boiler, do you think I can go for a 200 litre tank on the 18kw?
15Ltrs/min is not too bad and one wonders why the storage tank is running dry, perhaps it's a very small tank, or if the pressure is poor, it would be a lot less by the time it got the loft.
15Ltrs min is borderline for an average size combi, no point going for the bigger models, and you could only use one outlet at a time without affecting the others.
we told both that we require a lot of hot water and that our current system keeps running out of hot water
