- Joined
- 11 Jan 2004
- Messages
- 42,911
- Reaction score
- 2,685
- Country
Hi guys.
Mrs Secure and I have chosen some tiles which the tiler (rightly or wrongly) is a little unhappy about cutting.
We have bought 248 x 198 ceramics and for a border tile on top have bought a glass tile 200 long (can't remember the other dim).
We wanted two rows of the border tile, set in a "brick" pattern. Obviously, this neccesitates cutting tiles at the end of the run. The tiles have a painted backing which the tiler says may not cut cleanly and may show when up on the wall.
Also, we were under the impression that the glass tiles were, like the ceramic ones, to be separated by grout, but we have been advised that both their horizontal and vertical edges should be butted up without gaps.
Is that right?
Thirdly, we have been told it is imperative that PVA is applied to the plaster before the tile adhesive otherwise the adhesive will not adhere properly - is that correct?
I've already had a bit of a ding-dong with this guy because he said he wanted to use 40mm pipe throughout and I insisted he changed to a larger diameter once outside. He shrugged his shoulders and said "You are the client."
Also, he insisted that his "waterproof" tile adhesive was sufficient protection between the tiles and the plasterboard, but I have put my foot down and got him a tanking kit.
Well, I am the client....
I want to get my facts straight so I can be confident with him. Can you help with my tiling queries, please?
Is that right?
