Hi
I am installing spotlights in my batchroom which will be controlled by a nice IQ dimmer switch I have which will be installed outside in the hall.
I will also be installing a shower extractor fan (with a timed overun).
Ideally, what I want is the fan to turn on (not control its speed or any such nonsence) when the dimmer is turned on, in any fashion. Then I will also install the a 3 pole isolator to overide the fan.
This would be very easy if I wasn't using a dimmer switch, simply running the switched live from the light and a permenant live/neutral to the fan. How do I acheive the same when the dimmer will be droping the voltage of the switched live?
Many Thanks
Rob
Many Thanks
Rob
