Hi guys,
I'm new here, and I hope someone can help as this is driving me insane
We've recently had a new bathroom suite fitted. As part of the new suite we've got a new basin that has a mixer tap. The mixer tap is extremely noisy when the tap is fully opened and even louder when half opened, for both hot and cold. I've been looking around and this seems to be quite a common problem with cheap taps. We have isolator valves on each input pipe, and I have tried adjusting the valve to lower the flow but the tap is still extremely noisy.
Would someone be able to recommend a decent replacement quiet mixer tap? Or any other tips on how to reduce the noise, I've looked at Pressure Reducing Valves but I'm not sure if this is the right way to go.
We have a mains fed combi boiler, and the pressure shows as 1.5. The tap is fed from two plastic pipes that connect to copper isolator valves and the connect to the tap.
Thanks,
Dave
Thanks,
Dave
