We used to do something like that years ago with 3 lamps at college
Oops. should have said "automatically"
Even if only used as standby, there are benefits to being able to do this - one of them being the ability to fully load the genny for periodic runs using your own load (and perhaps even exporting some) to load it properly. Otherwise, all you're going to do it run it on light load for a while and then shut it down all oiled up.Running in either parallel or used as standby (I know of a few of these in this area). This type of system is sometimes used to allow changeover without loss of supply.
To your 3 I'll add - being able to sell your standby capacity to the grid as STOR (short term operating reserve).I could see a few situations where runing a fossil fuel generator in paralell with the grid could make sense.
You can buy small control modules that do it all automatically - I recall reading up on one range ... ooh ... must be getting on for 20 years ago now (so not new !). Little box of tricks (or collection of boxes) that will take care of starting your engine, running it up, adjusting the throttle, and closing the main breaker at the right moment. After that, they'll manage the throttle(s)* to share the load according to your settings.We used to do something like that years ago with 3 lamps at college![]()
Wasn't Westie was it?
I guess I must be missing something here. Apart from maybe 'sounding better' to have used a 'proper electrode tester', what is to be gained? In other words, under what circumstances could a measurement obtained by loop testing be significantly 'wrong'?Just a loop tester at the moment, but I will be hiring a proper electrode tester when my wholesaler decides to pull their finger out!
Are there likely to be any issues from the DNO? Have you had to deal with a similar situation your self?
I'm hoping the tester comes with instructions. We did cover electrode testing at college, but that was a lot of years ago now!
