Jig saw blade for cutting tiles?
26 Jun 2004
London
Are there any thin diamond blades to go in a jigsaw which can usefully cut out switch holes in wall tiles?
If so where can they be bought and which ones to avoid?
Most jobs I have seen they have used an angle grinder with diamond blade but the usual 110 mm is a little big. Are there any smaller diameter diamond blades which fit a standard angle grinder?
Tony
i used them on stone flooring and cut out for a waste pipe for a toilet brilliant finish would expect a reasonable finish but only a guess :D
why not ask if they have a spare tile you can practice on:cool:
Mark the hole you want to cut on the back of the tile. Cut hole from back of the tile with an angle grinder. Cut small bits at a time, turn tile over and check size of hole from front. This way you can cut small holes with a big blade. Or, mark your hole on the front, drill though the tile on the 4 corners, turn tile over, draw a pencil line joining 4 holes and using an angle grinder grind out to just past each drill hole. Job done.
Tony
I've used one of the jigsaw blades for a bit of DIY, worked great and I just bought it at B&Q as far as I can remember. Drill 4 corners out and join with the jigsaw, like a hot knife through butter. There was another thread on this not long ago and someone posted a video of a pro using a "toffee hammer" to knock through a tile in no time at all.
depends on the tile. for a ceramic wall tile they are great, but a decent floor tile or a porcelain, they are rubbish.
My brief experience of them was that they were rubbish for tile work - another tool on the job, a starter hole to bore, and as above, only good for thin or soft tile.
Perhaps i had a bad experience?
Between the modern bits, and a cordless angle grinder blade, most odd shapes can be cut out - anything straightforward can be opened up on the wet saw.
Well I have started my tiling in a small toilet to give me some practice before doing the rest of the 20 m sq walls!
The lightswitch luckily happened to be between tiles and I just cut lines 10 mm apart and snapped each finger off. That was easy!
Tony
Yep...the way to do it and you can do it this way also on a wet saw....
Or look at my video on you tube... :LOL: ..tictic70 lol
Tony...big chez from uhm has a video off the one with a wet saw...
Next time get your set out ...correct...before any tile fixing... :D
