No.... see op profile ...
What do you mean?
There's two photos of his switch wiring on his profile.
You mean Yes.
No he MEANS No - because it hasn't been put up on the post by the OP. - well he has answered that bit - now wait for the next bit.No.... see op profile ...
What do you mean?
There's two photos of his switch wiring on his profile?
You mean Yes.
Not the best photographs (see op profile) but it looks like there is no neutal at the switch, or within the switch cables.
Therefore you need to find somewhere else to get a permanent live, neutral and earth.
If the ceiling wiring is out of the question, consider feeding the new light from the socket circuit, via a fused spur unit (3 or 5 amp).
Thanks for comments.
No, I can not access (nor see) the junction box.
Yes, I have found another wire incoming with live, neutral and earth (i know this time!). This one actually used to power another wall light and is terminated in a junction box currently. Could I connect the neutral from my new 2-way circuit to the neutral in this junction box perhaps? sry for ignorance here by the way..
Just noticed where you found the neutral, the light fitting has been removed, so you may have to test with a voltage meter, or even connect a light to the cable for now (make sure the power is off before you do any work).
I doubt it - if he behaves anything like last time, he'll just continue to stubbornly refuse to acknowledge that the photos even exist, even after you have put them into a forum message for the OP. I despair!BAS doesn't believe in helping people on this website. No doubt he will now shout and ball about me uploading the photographs for the OP.
Hi, thanks, yes I turned off the power and connected a spare lamp. Not very lucky I guess since the cable with live, neutral & earth is on a separate circuit (at switchboard) from the 2-way,2-gang circuit..any chance then or all hope lost?
Perhaps both circuits could be lumped together at the fuseboard. Yes, perhaps I could - although I never touched the fuseboard, but perhaps easy enough with wires sticking out below etc.
Are they both lighting circuits? Yes.
If so, how many lights on each circuit?
- 1 on the cable terminated in junction box..therefore quite unlucky i thought.
- 20 on the one where new 2-way,2-gang will be (if successful). 15 of these are led downlights though in livingroom/kitchen.
Are there other lighting circuits besides the two circuits in question?
Yes. We seem to have one circuit for each floor in house, so there is one other for next floor up. That one has 10 lights as well perhaps - in 6 rooms.
thanks,
It would seem the two circuits could be made into one at the fuseboard, not necessarily a DIY job.
Are both the lighting circuits in question 5 (or 6) amp at the fuseboard?
