I need help in working out what 12v power supply I need to purchase if someone would be so kind to help me get my head around calculations.
I have some 12v dc to 5v usb converters that I will have around the house in some media back boxes and am looking at a central 12v dc power supply. the kind of wall mounted metal box used for CCTV/Access control. (I will be using some of the 12v for 12v items not only the 5v converters)
Anyway the converters provide a maximum current output of 2a (I might want to update these in the future to 3-5a should the need arise).
So to provide 2a @ 5v what would the current output for the 12v supply need to be? (maximum distance of cable length around 10m between 12v supply and converter).
What is the calculation I need to then work this out at say 3a @ 5v etc..? Do you require any more information? I know where to source the supplies from I just need to know the 12v can output the required amps (as some will output maximum 1.6a per output and some only 1.1a) from TLC anyway.
Thanks in advanced.
Thanks in advanced.
