Appreciate any help as now run out of ideas.
I have relocated and changed a terminal box that joins a power supply, dimmer switch and light. This has necessitated using new cable.
I took a photo of the connections in the old terminal and have reconnected accordingly.
3 earths connected
Live from power to live from switch
Neutral from power to neutral from light
Neutral (switched live) from switch to live from light
Needless to say the light will not switch on.
The live wire into the switch is connected to Com, the neutral to L1.
When the light is wired directly to the power supply, it works.
There are 240 volts at the light switch.
Anything obvious that I should check pls?
3 earths connected
