So you are going to be running the cables and allow a spark to do the actual connections?
Running the cables I would class as needing to know how to design. There is more than just running the cables. It needs to be designed first then cables ran to the design.
Are you going to be notifying building control?
Do you know about building legislations (Part L, Part P) that apply and safe zones?
Are you planning to get said spark to do the design first tell you where to run the cables and then do the donkey work your self? Or just run the cables and then get the spark in?
You do not have the competence to do this work. There is more than just running cables. What about ring finals and radials? Do you know where you would use one or the other? Do you know about earthing requirements?
I have worked out the cost of parts you require with my trade discount and I have selected MK logic for accessories, Doncaster cable, Hager all RCBO, including all parts I would consider requiring (screws wall plugs capping), without the lighting to around £425 including VAT. This gives a really good design.
I cannot remember is Part L applies to new builds or rewires. If this is the case for a rewire then 30% of the fixed lighting fittings must be low energy fittings. This is to comply with building legislation that you have to comply with.
This is why I did not select cost of lighting into my price.
Hi Adam, to answer those questions.
No I won’t be making connections, just running cable.
I would notify building control if they offered a consultation service that I already pay for as part of council tax. The work will be inspected and signed of by a qualified electrician
I know about part l, part p, look at previous posts. I’m aware of safe zones in relation to bathrooms. I don’t intend to have any sockets in the bathroom, the shaver point will be nearest the sink, well away from the shower. The extractor fan will have its fused spur outside of the bathroom, or I may decide to use a wall mounted switch well away from zones 1,2.
GROUND FLOOR
Electric cooker on 6mm cable running to C/U,
Boiler on same cable
All sockets to kitchen to run on its own ring circuit to C/U
Extractor fan for cooker to run off spur on kitchen ring circuit
Lounge ring circuit + double socket to hall to run on its own ring circuit to C/U
All lighting points on ground including hallway light to run on same circuit to C/U – I don’t know whether it is loop-in or junction box, this is where my sparky will be able to advice, perhaps you or someone can here ?
1 Pendant light to hall used with two way switch operable from top and bottom of stairs - don't know how this is done, dependent on advice from ex-sparky
FIRST FLOOR
All lighting on first floor to run on same circuit to C/U
All sockets to bedroom 1 and 2 and double socket to hall to run on same ring circuit
Extractor for bathroom to run off spur on bedroom ring circuits – fused switch to be outside bathroom or wall mounted outside of zones 1,2 relating to shower. Shaver point to run off bedroom ring circuit, to be placed well outside zones 1,2
PLASTIC PLUMBING PIPE USED THROUGHOUT. EXPOTENTIAL BONDING USED OUTSIDE ON INCOMMING COPPER WATER SUPPLY AND ON GAS PIPE OUTSIDE. WILL DEAL WITH THIS AS ADVISED BY QUALIFIED SPARK WHO MAY DO BONDING TO REGULATIONS WHERE NECESSARY – i.e. boiler ???
Not rocket science... If there are mistakes please correct where necessary.
