UPVC Aubi 05058 Window Lock Failure
30 Jul 2014
Berkshire
Our 10 year old UPVC windows are fitted with Aubi 05058 locking mechanisms. We have just had an incident where the mechanism (centre spindle gearbox) has sheared inside upon closing a window. This leaves the window locked at the offending catch. We have fitted a new gearbox and on stripping the old one, the design looks delicate. Prevention is much less painful that cure when this happens.
The question for you professionals is please:
a) has the gearbox design be strengthened in the last ten years
b) should I replace the gearboxes before they fail
c) do they wear inside and are we likely to see other windows doing the same
Thank you for your expert views gentlemen.
i would suggest that if the window needs adjusting and maybe harder to lock then maybe this could put more pressure on a gearbox.
Our 10 year old UPVC windows are fitted with Aubi 05058 locking mechanisms. We have just had an incident where the mechanism (centre spindle gearbox) has sheared inside upon closing a window. This leaves the window locked at the offending catch. We have fitted a new gearbox...
I have two windows now unable to open due to failed Aubi gearboxes. How did you get the window open to get access to change it?
If mine are anything to go buy, you will need to remove the glass to be able to flex the frame passed the locking pin. You will know if the top or bottom is the cause. Our window did not have enough room to get anything in to retract the lock. If you are not a practical person, the Window Doctor or similar may be your best best. Good luck.
