Hello All,
I'm fitting a new bath and wanted to use flexi connectors for the taps.
Only snag is, the system is gravity and it seems that 'full bore' flexi hose is actually about 14mm, not 22.
If I use a flexi, do you think that will have a drastic effect on the pressure from the thermostatic mixer tap I'm putting in? The water pressure to the current mixer tap in the bath is already pretty feeble.
Far as I can see, there's no such thing as a truly full bore 22mm flexi... Is there?
