You need to fix the damp problem or your wall will crumble
What's the best way to fix that? I'm guessing blasting the hole with an electric heater for an hour won't really do the trick?
There is decking outside and the electrician suspects that it hadn't been sealed properly so water must have seeped through over the years and eventually caused the problem. Maybe I need to seal it along the outside wall with something?
