talbot pushfit fittings
3 Feb 2010
Sussex
hi all. can anybody tell me how to undo talbot pushfit fittings, i had a leak on one the other week after it froze ,turned water off and tried to undo the dam thing,didnt have any joy so i went to the local plumbing merchant to see if there was a special tool for the job, the guy there went onto talbots web site to see if there was but found nothing, he told me that they dont undo you have to cut it off the pipe. doesnt sound right to me, idid cut it off the pipe and took the fitting back to them to see if they could undo it, no joy. the fitting is black in colour and connects to the blue polypipe stuff any ideas, i cant send a pic as i am computer stupid,
I think these things are actually demountable.....a plastic tool called an extractor is clipped onto the pipe, then forced up into the fitting, dislodging the wedge that grips the pipe, allowing the pipe to pull clear.
Generalising though, although most plastic push fittings are demountable, some most definitely aren't. I don't usually use a fitting twice, although new 'o' rings are often available...I just don't like the risk.
John :)
cheers for the reply mate,sorry for not responding straight away,as i said iam computer thick, so your saying that there is a special tool for these,but some push fits arnt demountable
As far as I can remember, Talbot have 2 push fit ranges...one is called the pushfit and one called the gripper (which is for heavier duty use I think, and has collets that you turn to tighten them). I believe that both are demountable, using the correct extractor tool with the pushfit.
Other makes (Marley etc) produce fittings that may, or may not, be demountable.
Either way, if you do demount these fittings, you are relying on the 'o' ring within being in perfect condition, and the pipe itself being completely free of scratches.
John :)
I just came across this thread while trying to figure out how to undo these fittings myself. You do need a tool for doing it with, I made one up myself to remove the fitting from some 20mm pipe. I used a piece of 22mm SS tube, which I drilled a 20mm hole through. Then I tacked an M20 washer to one end and cut the tube and washer in half. This allowed me to tap the tube up the pipe and into the fitting to loosen its grip on the pipe.
Well done mate, now prepare yourself for the wicked witches who will now try and down you for your valuable ideas. They hate anyone coming up with problem solving ideas. (you will see, just keep watching this thread)
