I am getting an oil fired boiler for an annex, it is planned to have underfloor wet heating, i presume I can use a combi boiler with underfloor heating?
To be frank, oil combi boilers are not great for hot water performance, but you may only have limited HW requirements....dunno??!!
Also, standard steel jacket oil boilers are not great with low return temperatures either but with careful design, this may not be an issue.
If it's into a concrete screed & you only require a low 'mean water temperature', again careful design will be required.
