Recent years have seen a proliferation of the numbers of circuits in people's homes, what with conservatories, outdoor lighting, garden pond/water feature pumps, powered outbuildings, shower circuits, separate kitchen/utility room circuits (in addition to the cooker circuit).
When you add them all up, even with diversity you're going to come to more than 100A. Presumably this means that the main switch on the CU should be rated at more than 100A? They seem few and far between - even 16-way CUs still come with 100A switches.
In theory should you reduce the capacity of breakers (e.g. drop rings to 20A) to keep below the 100?
If you run with a bigger main switch, or multiple CUs, what's the largest service fuse that (typically) a supplier will provide for a 230V single-phase supply?
