- Joined
- 27 Jan 2008
- Messages
- 23,909
- Reaction score
- 2,707
- Location
- Country
I need a new wireless thermostat, I was going to go for a cheap programmable however then I noticed the LighwaveRF Home Thermostat it states "Control and set heating schedules and timing via the free App (requires LightwaveRF Wi-Fi Web Link)" not sure if the thermostat is wireless? or if it will work without the LightwaveRF Wi-Fi Web Link? However I then noted it will also work sockets.
Now I have a problem with alarms, and one idea to get around the problem was a pneumatic time switch down stairs to work a socket up stairs so I can turn off the alarm without going up the stairs. It seems LightwaveRF will allow me to do this without all the hassle of hard wiring.
So with duel use the LightwaveRF looks more appealing.
Hive also do sockets, I think there is a Nest one? and also something called Energenie MiHome, the latter never heard of before, £28.28 for socket, control gateway £48.47, they don't seem to do a thermostat but do TRV units £74.99 for two. The bit I like is the remote control £8.49 which you can get, and it seems they also work with Nest?
However the hard bit is working out what bits you need?
So if I get just two Energenie MiHome TRV heads £74.99 and a central control gateway £48.47 and a socket £29.28 with my wife and I already having Samsung Phones is that all I need? £152.74 is a fair bit to pay out, but if it cures two problems then not so bad. Can add the remote control latter if I find we need it. Same goes for nest thermostat can add latter if required but likely not required when two main rooms are temperature controlled.
Or are the other makes better?
Well could not wait, so Energenie MiHome TRV heads, central control gateway and a socket have been ordered, crossing fingers that it does the job. Idea is to move existing thermostat back into hall and install the heads in mothers bedroom and living room. I will update once fitted, it was quite a bit cheaper than expected from Electrofix.
Well eTRV's fitted, the socket still to be done. I have also moved the main thermostat back to hall, the two rooms are slow to cool down, so as yet not sure how it's going to work. Not sure what to set the time clock to? I think having it switch off at say 5 am and back on when the valves are set to heat rooms at 7 am should ensure boiler is running when they call for heat.
The programmable thermostat I will set temperatures really low then use as a simple thermometer and clock.
