D
Doggit
Which is a bit odd seeing the chimney would have had real flames and hot gasses going up it when it was first used.
With an open fire the hot gases are diluted and cooled by air drawn from the room but which has not gone through the combustion area. With log burners there is no room air to dilute and cool the gases going into the flue as it all passes through the combustion area.Which is a bit odd seeing the chimney would have had real flames and hot gasses going up it when it was first used.
I think that he was teasing you.That is not what HETAS told me. HETAS said it is to prevent ( reduce the risk of ) the brickwork of the chimney becoming hot enough to ignite flammable material in contact with the brick work.
Are you suggesting that combustion can take place when void of O2?With an open fire the hot gases are diluted and cooled by air drawn from the room but which has not gone through the combustion area. With log burners there is no room air to dilute and cool the gases going into the flue as it all passes through the combustion area.
Bricking up the fireplace opening is not acceptable as smoke is re entering the fabric of the buildingI did contact HETAS Doggit and they advised things that have been done. I emailed the chap to explain after another visit things were not resolved and he said that I need to escalate things to an official HETAS complaint as he couldn't advise anymore and they wont attempt a visit unless a complaints form has been filled in. Shame really as it isn't a 'complaint' as such - more a request for another more experienced eye to have a look and work with the installers. I did mention to the installers that they'll know a hell of a lot more by the end of it if we ever resolve it. There solution was for me to brick up the chimney opening but I'd rather not cover up the problem. And when I fit a vent into the fireplace...as I assume you should....I'll be back with the same problem. Even if I put the vent outside on the stack I'd still be worrying about a potential chimney fire so we do need to get to the bottom of this somehow. I await HETAS advice now...I'll keep you posted on what they suggest. Cheers
