Intergas...but which...
"Gas went through it all, right to the living room"..
:ROFLMAO::ROFLMAO::ROFLMAO:...and another keyboard fooked..
Stop digging a hole for yourself. You just clearly do not know. Read the book you have. All sorts of valves and devices are inserted in the weep line, room thermostats amongst them.
Stop dig a hole for yourself. You just clearly do not know. Read the book you have. All sorts of valves and devices are inserted in the weep line, room thermostats amongst them.
Show me this room stat..
I don't recall saying that a relay valve that utilises a weep tube doesn't exist?..maybe you can highlight where exactly I wrote this?..I will admit saying that a room stat utilising weep tubes would be a figment of hard-ons imagination.
"gas weep pipes"??? :ROFLMAO::ROFLMAO:....@ least try to google the correct terminology when referring to gas controls...:rolleyes:
You did refer to the whole concept of main vlave control by weeping gas as a load of bo||ocks
Tubes or pipes. Small difference, did gas weep pipes go from the boiler to room thermostat and then continue on to a timer or manual ON-OFF control before delivering the weeping gas to the weep burner next to the pilot light. Apparently they did. A series of controls along the weep pipe. The last weep control before the weep burner would have been kept open only by heat from the pilot flame ( bi-metal strip ) to ensure there was no weep flow if the pilot was not lit and hence no main burner flow..
One reference ( not public domain ) refers to two or more ( weep ) room thermostats being connected in parallel so that either or both being open ( call for heat ) would open the main gas valve.
Here are my second editions..... Great reads.
Did you take a photo of your 2nd edition with a publication date before 1999 ?
Sorry Bernard my mistake , I aquired the book around 2010 as you quite rightly said.
I confused the dates with the following books which I aquired circa 1979 which were on the C&G curriculum.
Although confusing the dates of when I aquired these books was an oversight, unlike yourself trying to be a smart azz by implying that I should purchase these books in order to expand my knowledge.
What else have we here that was on the C&G curriculum?????..oh yea...
Anything else Bernard??
There you go. Look at `J`. :LOL: ! Full modulation of the burner, injecting the correct level of heat into a house, controlled by variable acting boiler stat & `room thermostat` and no electrics at all. You can tell all the GasShark registered in the Combustion Chamber thread all about it.
