- Joined
- 27 Jan 2008
- Messages
- 23,734
- Reaction score
- 2,675
- Location
- Country
I have a problem, a garage built next door means there is not enough room to put a ladder up to the chimney, and access aerial and mast head amplifier, we have two aerials and two feeds from mast head amp and there has been a problem for some time, at the moment there are two power supplies one has no aerial connected to output but switch it off and other one fails, the other one feeds a second pre-amp and although not ideal it works.
From this point we have coax cables feeding three more rooms, two have new cables and we have three satellite boxes one being a Sky HD so even if Freeview totally fails in three rooms we still have TV.
However Mum’s bedroom down stairs has an old cable which is now failed, still getting some signal as the TV was able to find channels when a scan was done, but not good enough to watch.
So either I have to run an new cable, which at £7.30 for a reel is a cheap option, or we can use something like the Nikkai 5.8GHz Phono Video Sender Kit at £49.99 from Maplin which means we can also get a second receiver at £19.99 and get TV into my bedroom too. The quality of coax signals are not the best, in theory I should be able to watch the Sky HD box in our upstairs living room, however the picture is such a poor quality we rarely do, if the video sender kit is as good as coax then for my mother with macular degeneration it is good enough, she does not have HD eyes in fact worse than standard TV signal so no real need for a HD signal.
Maplin are known as being expensive so I wonder if there is a cheaper option? Exactly where it would go I don’t know, maybe up stairs and use three receivers one in each down stairs room and one in my bed room, then we can watch Sky in every room, plus of course anything recorded from Sky.
So thoughts please, and any ideas of which video sender kit to use? To me worth the extra money to be easy install and not only giving TV to mums room, but Sky TV to other rooms as well. I know it's not HD, but coax is not HD either.
