Thanks, I think I would prefer to go down the route of a solder joint. I will attempt this but need to allocate plenty of time just incase. I've attached a drawing of where I think I should place the magnaclean. Does this look correct.
Also, before dismantling and cutting the pipes, is there anything I need to do other than drain the system? I assume I need to turn the boilers electrics off? What happens if someone turns a hot water tap on shouldn't be a problem right? they just wont get hot water. If you can kindly list everything that needs doing in order that will be great. Thanks.
