I'm fitting spots in all the rooms and after installing them, have tested them by wiring into the ceiling rose switch and neutral side.
The problem now is that I want to remove the ceiling rose. I've done so in the first room by disconnecting the rose and putting them into 4 seperate terminal connectors but the problem is how to recess the joints into the ceiling?
Each rose seems to have an average of 3 looms coming down through a hole above the rose in the wooden reinforcement which the rose fixes to. My problem is that I cannot push the cable with connectors into the ceiling, even after scrapping some of the plaster away. And I cannot drill out the cable hole in case I damage a loom.
What do the professionals do please?
