Crimping
14 May 2009
Tintagel cornwall
hi all I’m a heating engineer and I want to do more crimping for ease of wiring etc. Off boilers it’s is 3 core in white sleeping not grey and is about the same diameter off pumps and zone valves.
My question is what width is each individual wire and should I use the blue or red pin type crimp
Thanks in advance sorry if it’s a daft question
Red is for 0.5mm² up to 1.5mm² wire.
Wires are measured by cross-sectional area.
The flex in question if loose is likely to be 1 square millimeter,
That fitted to pumps and valves, perhaps 0.75mm².
The squash flat blue and red crimps are not very good or suitable, but are what is used.
Why do you want to do this?
Aren't all the cables in a wiring centre with screw terminals and cable restraints?
I was looking at the pin crimps, reason being, wiring loose threads of wire into many blocks on air pumps and boilers are difficult as the space is so small.
On many heat pumps from Europe the wires come with a pin type crimp on the wire. Makes it a lot easier to wire. That’s the only reason
Is there any pitfalls with using them in these circumstances
Correctly sized ferrules and a proper crimper would be better.
The squash flat ones are rubbish.
Having been using that style of ferrule for quite a while, I keep meaning to buy some uninsulated ones (like this). I often find terminals where the insulated ones don't fit well, or there isn't space for the insulation (little distance between terminal and cable clamp for example), and the insulated ones are particularly bad if you have to put more than one wire into a terminal. Using the uninsuulated ones gives you the benefits of not struggling with "whiskers", but without the problems that can be encountered with the insulated ones.
I also sometimes wonder what someone coming acroos my work later one might think - it seems many sparks have never heard of them, I certainly recall seeing the spark replacing the CU for a mate struggling to understand why they didn't crimp very well as he squashed the insulation on the ferrules I offered him when he was shortening the RCBO tails :whistle:
There are two main colour codes for insulated crimps. One is French and the other German.
But the OP started off talking about this type (so that's what I was referring to)...
ML83E_1
...and was swayed toward bootlace ferrules later. I'd be interested to know if there is a proper spec for this type, i.e. DIN/ISO/IEC/etc?
