Problem replacing dimmer switch with standard switch
2 Jul 2018
I've decided to change the light switches and plug sockets in my living room after decorating and I'm struggling to replace the main light switch. At present I have a 2 way dimmer switch which I want to replace with a standard 2 way switch but unsure how to wire up as there are no labels / markings on the inside of the existing dimmer.
Attached are some pics showing the existing dimmer and wiring and the new switch I want to fit.
Any guidance would be greatly appreciated.
As far as I can see it is not two way, it is just two pole, as to of it needs to be two pole don't know.
So question can you work the light from two different switches?
No, its just the one dimmer that controls two lights - one living room and the other in the hallway
No you don't.
Those go to one gang of your new switch, the others to the other.
Please spend a bit of time learning how it works - you ought to understand what you are doing, not be fiddling with wires without knowing.
Thanks for your reply. Its probably quite obvious that I'm not an electrician and don't know very much about electrics!
What I should have said was the label doesn't give much detail to the layman and isn't straightforward - the other switches that I've replaced like for like had COM, L1 & L1 markings so they were easy enough to change over. The label on the dimmer doesn't tell me anything.
I would love to spend some time reading up on how electrical circuits work but don't have time at the moment - I would really appreciate some assistance in wiring up the new switch as I'm unable to use the dimmer with the new ceiling light that I've fit.
As the new switch has a metl front plate ALL the earth conductors in the cable MUST be connected securely to the Earth terminal on the switch plate.
Label the Live Feed conductor before disconnecting and "losing" it.
The two Comms nust be linked together.
If you are going to any more electrical work then you need to find time to read up on basic electrics. Just because "it works" does not mean it ia working safely.
Not a good basis for doing electrical work.
It tells you "connect wires either way round", which is what applies to COM&L1 or COM&L2.
They do, rightly, expect a degree of competence.
Unfortunately any reality of not having time will not protect you from any realities of problems and risks arising from attempting electrical work when you don't know what you are doing.
I'm saying all this not to criticise, or score points, but because it really is in your own best interest.
