stuck service / isolating valve
15 Sep 2017
Sussex
How do I free? (mixer tap is leaking, needs new washer / disc)
Its a compression fitting on sink hot tap (the inlaws).
Unfortunately its already had its screw slot a bit chewed.
I thought heat might work, then penetrating oil.....
system is in a bungalow, hot water tank same level as boiler, seems to have pump on hot water from boiler to tank coil. Havent looked to see if there is a stopcock on the hot water out of top -is that likely?
Cheers
Yes, if you stop the cold entering the cylinder then the hot won't be pushed out.
If there's a stop on the cold inlet (usually low down on the side of the cylinder) then use that or check the loft tank for a stopvalve on the cold water feed to the cylinder. All this asumes you have an open vented system.
If it's a mains pressure cylinder then close the incoming cold main.
