- Joined
- 27 Jan 2008
- Messages
- 23,811
- Reaction score
- 2,693
- Location
- Country
I have a rear push bike light which is charged from USB, not really what I wanted, but only one I could find which bolts on to rear bike rack. Put it on charge down stairs and green light comes on and stays on, and after over night charge, switches off after 20 minutes of use, but put on charge upstairs the charge monitor shows it taking 0.20 amps and after a few hours green light goes off, and it will run for about 6 hours.
However same lead and charger socket both up and down stairs will charge phone and tablet without a problem.
Once it is flat again I will move monitor down stairs and see what charge rate is, however puzzling why leads and charging sockets which can charge phone or tablet at around 0.9 - 1.2 amp fails to charge back light at 0.2 amps.
I had problems before, which is why I bought the volt/amp meter that plugs into a USB outlet, in the main I found leads from Pound World was the problem, they worked, but very slowly, and over time I have been getting rid of these leads. However why it should work with one item which draws a high charging current, and not with another which in comparison draws a very low current, I can't understand.
