PIR wiring replacement
13 Nov 2008
Avon
Morning,
I am replacing the PIR on my outside wall lamp.
The wire i am using from the NEW PIR are,
BLUE BROWN YELLOW
The wire from the OLD PIR were,
BLUE BROWN BLACK
Is it ok to assume the wiring image i show is correct in that,
BLUE - BLUE
BROWN - BROWN
YELLOW - BLACK
Sorry i forgot to advise PIR wires from the PIR unit
RED = LOAD OUT
BLUE = N
BROWN = L
I cannot follow your wording.
In the first post text you list three wires but in the picture you have four -
and now a Red has appeared.
Yes i messed up sorry.
The wires in the first post relate to the extension wire that i will use.
The second post is the actual wires that exit the pir & into a block connector.
I suppose the best way to ask is the wires from pit to connect to house wire.
Does that make sense
House wires
BLUE
YELLOW/GREEN
BROWN
New Pir Wires
RED
BROWN
BLUE
I took it apart like this
HOUSE BLUE = LAMP BLUE & PIR BLUE
HOUSE YELLOW/GREEN = LAMP GREEN
HOUSE BROWN = PIR BROWN
LAMP BROWN = PIR BLACK
The new PIR wires are
RED
BROWN
BLUE
