- Joined
- 26 Mar 2019
- Messages
- 4
- Reaction score
- 0
- Country
Hello,
I have been looking at an ongoing issue with noise at a property. It only affects the bathroom/boiler. I have renewed the stopcock as it wasn’t turning the water off, the tap cartridges have been swapped out. The noise is only on the bath or basin when the hot water is ran. I have isolated other taps, electric shower and wc cistern to rule those out, the noise is still there when boiler is turned off on switch, so water related?
Boiler: Vaillant EcoTEC pro 28
Noise was there before stopcock change, intermittent noise, and seems to stop half turning iso valve.
I have changed iso valves for full bore and still doing it,![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
and checked flow turbine and inlet filter, all good. No water meter in the property either. Boiler and bathroom have been installed approx 11 years, noise only started within the last year.
Current temp repair - isolation valve under boiler reducing flow slightly
Yes I do have this thread on another forum.
