- Joined
- 27 Jan 2008
- Messages
- 23,854
- Reaction score
- 2,699
- Location
- Country
Praying on my mind are a number of items connected with heating my domestic hot water using my oil fired central heating boiler, thoughts welcome.
1) Plumber tells me I should not fit a motorised valve to the domestic hot water as there is no over run built into the boiler, so it could over heat if the thermo siphon is prevented, due to fitting a valve, the bathroom radiator and cistern hot coil can’t be turned off as it stands, except by turning lock shield valve on bathroom radiator, which only stops radiator working, hot coil is heated whenever boiler fires up, is he correct in what he says?
2) He says a by-pass valve is not required, the pump is on the return from radiators, and it has been found if one zone pump runs it causes the water to reverse flow in the other system, plus upstairs radiators heat up with thermo siphon even when no pump is running, so he is fitting motorised valves which will be electrical linked to pump so until valve is open pump will not run, unless the micro switch in the motorised valve sticks, is he correct that by-pass valve not required when every radiator is controlled by a TRV?
3) There is no thermostat on the cistern, so in the summer only control is time boiler runs for, at moment set to ½ hour a day, it would be hard to run wires between the cistern and the boiler heat link to control the temperature of the domestic hot water, and even if run, since no motorised valve it would only do anything in the summer, I note even at just ½ hour a day the boiler cycles off/on as the temperature hits 81°C when boiler turns off and 55°C when it turns back on again, so it would seem not needing full ½ hour, but that is the smallest time slot Nest will allow. Years ago I bought a wireless tank thermostat, but can’t seem to find any now, at least at a reasonable cost, I can buy a wireless room thermostat for £20 so to pay over £100 for a tank thermostat seems OTT. I am sure one can buy some wireless relay at under £30 but not found one that would not need an enclosure making for it which clearly lifts the price. However the first question is do I need it anyway?
So some back ground info, the boiler is a Greenstar Utility 18-25, the house is built into the side of a hill so three levels bottom side and two levels top side, boiler in the ground floor bottom side, which is a self contained flat which was a garage, when we moved in we found central heating had been altered so the time switch in the utility room centre floor simply turned it off/on and there was no longer an ability to select central heating or domestic hot water, there was a RF thermostat receiver down in the flat, but no transmitter, only the flat was temperature controlled with a wall thermostat switching on the pump for flat radiators, the pump for house radiators was simply on a 13A plug so you could run it if required. There were 3 fused connection units taking power from two independent fuse box/consumer units, and between main house and flat wire colours changed and there were only two out of three connected. Also floor failing under the cistern and electric shower, both showers leaking, both instant electric type.
So chippy and plumber employed to do emergency work to stop cistern dropping into floor below, and repair rotten beam under shower, replacing tiles and shower tray, he got a full set of TRV’s to replace all existing, but ran out of time, so is to return next week.
In the mean time I needed to sort out wiring, so pair of wires between flat and main house now used to connect Nest heat link to wall thermostat to give it 12 volt power, the heat link fitted in flat, and all power now taken from a single FCU and all ready to wire in the motorised valves when the plumber returns. The new arrangement gives house priority the flat thermostat will run motorised valve and pump, but not the boiler, it is likely to be rarely used, and if house has turned on the boiler it should be enough to heat flat when we have visitors, the main house central heating and hot water will be controlled by generation 3 Nest.
The hope is when winter arrives all will be in place, the Nest is paired with four energenie mihome TRV heads, so the three areas dinning room, hall and living room should all be at same temperature.
Considering adding EQ-3 Bluetooth Smart Radiator Thermostat (UK) 142461D0 to four rooms upstairs, at £15 they are a lot cheaper than the energenie mihome TRV heads, and should allow us to switch rooms off/on as required without needing to access the TRV manually. Plus maybe some manual programmable heads for kitchen and bathroom and maybe flat.
So thoughts please before the plumber returns, as he will be draining system and refilling with new inhibitor so if there is an error want it sorting before system refilled so don’t have to buy more inhibitor latter.
