Toupret for skimming walls
30 Mar 2015
Based on an excellent suggestion from this forum I’ve been using this Toupret product for small and relatively large filling jobs. It’s been perfect and I’ve become very familiar to it. I use the large 12” jointing knife and it always provides a great finish.
I’ve never skimmed a wall using plaster and was wondering if I could use my experience with toupret and extend this to skimming entire walls using the Toupret product? I am taking paper off a wall soon and expect some imperfections with this.
Can someone please provide direction on the above please?
Thanks in advance.
Im not a plasterer but I'd never use something with filler on the packet to skim a wall!
Is there a similar product that I can use for skimming? I’m not confident with using the multi finish with a trowel.
I’ve heard of people attempting to do that, it’s a pretty cr@p idea and would generate a huge amount of dust, and can’t see it giving a decent finish.
There’s no other filler that’s any better either, hence the existence of finishing plaster.
Ive used this for mass filling, way back I posted on how I used it to get good finish with minimum sanding
Found it, https://www.diynot.com/diy/threads/...-mixed-jointing-compound.473237/#post-3797277
Why dont you have a go with multi its a much better job than anything else , if you mess it up you can then fill it.
a refina sponge float is useful for flattening out or getting a wall back if you start to loose it
Watching with interest as I also have a large number of old walls that need a mild spruce, 115yo Lime plaster, super flat, but the finishing layer is slightly friable in places, and we have had chasing work to re-wire, so as the papers coming off its a case of either made good and paint, or using a heavy lining paper. Want to avoid a full skim as that would loose features on the skirting/mouldings/broomsticks etc.
Daniel
Daniel
(Powdered) Filler (where needed, not an attempt at skimming the entire wall), then lining paper.
Yeah, I saw a youtube video of someone in the US who was 'skimming a wall' by as far as I can see putting a sandable filler and or jointing compound on and then taking the majority off before sanding it. Like you would filling a hole, only for the whole area of the wall. Obviously gets a smoothing effect without adding any real thickness, which is what I am after.
Obviously depending how it goes, if you are picking up a lot of small bits in the filler coming off the wall you could get in a right mess, and it is slower than skimming the wall. Skiming would make perfect sense in everyway if it wasn't for the fact I dont want to loose all the detail on the mouldings/corners with a 1/4 layer, and because being solid lime walls I don't want a layer of gypsum plaster over them either.
For the two main rooms downstairs I think we will stick with thick lining paper and done previously for various reasons, including including speed and the ability to get someone else to do it.
We still might need to look at giving it a mist coat or something to tie back the small bits and dust from forming lumps behind the paper. Decorators are due Sunday morning to have a look over the job.
Then we can do some testing in one of the bedrooms and see what we can work out for getting a good finish out of the job, and then either apply that elsewhere or revert to lining paper!
Daniel
Thanks Daniel. My attraction to using a product like Toupret (or easifill I think) is that I’ve used it in large areas as part of filling and am comfortable applying this with the large (12”) filling knife.
I’ve never used multi finish or a trowel.
