- Joined
- 27 Jan 2008
- Messages
- 23,871
- Reaction score
- 2,703
- Location
- Country
I have fitted light switches which can be controlled from outside so I can turn on lights when I arrive home.
My bedroom has three GU10 bulbs, all LED, with new Energenie switch they started to pulse, though OK fit on tungsten bulb, turns out bulb was dud, but with only two lights, no pulsing, so took the one bulb and swapped if for a bulb used in kitchen same make but different colour temperature. So now no pulsing.
Two things, one why should an on/off switch cause lights to pulse, switch can be heard to click when switching off/on, and two why did swapping a bulb stop it?
If it had been a dimmer switch OK, but just a on/off wifi switch.
Also for G9 LED bulbs how does one know if they will flash, the 3 watt x 5 in wife's bedroom flash or pulse maybe better word when switched off, I suspect they are non dimmable and I need dimmable but is non dimmable written on the bulb.
Found bulbs this one is dimmable but this one the odd one out is not I had expected to find problem was non dimmable bulb and the switch has a small let through current to work electronics, but if dimmable then not sure what will cure problem? Think they have plastic covers on bulbs so tungsten not an option.
