There are regs to do with retaining the external door between the house and the conservatory. Nothing to stop you removing it but selling would be complicated a bit. Quite likely to be a bit cold as well
No, please, stop.Also the door is always open and there is no stoppage for the heat to be lost.
We have also provided an extra radiator on the conservatory to overcome to the heat loss
That sounds brilliant ..... for those nice summer days.Have you considered switching this to an electric panel heater then powering it from solar panels on the conservatory roof?
The thing is you may not find the room cold but you will be using more fuel to maintain a certain temperature. You can heat up a poorly insulated building like your conservatory and keep it warm but you are using more heat due to the heat loss . ( You are not overcoming the heat loss ,if you see what I mean ) As some have said, it is your house ( and your fuel billsWe have also provided an extra radiator on the conservatory to overcome to the heat loss but I can confirm that the conservatory is not colder than the rest of the room.
yes but heat loss is proportional to the area, and the area of the sliding door is much less than the glass in the conservatory. Also the floor in the conservatory probably has even less insulation than the glass.Thanks, but this does not make sense because the sliding door is glazed and heat loss already occur.
