Your Rad system will still require balancingand it does not require fiddly balancing
Not correct, you are assuming that all TRVs will close, never seen that happening, in theory yes, but in reality you will have to balance the systemWith TRVs all round you can run with the locksheilds all wide open, so it does not really "require" balancing as a standard system would, the TRVs will do that for you.
Of course if you are starting the system from cold, then the rads nearest the store will heat first, but once the heating is left on for some time the rads will all reach their equilibrium temperature for the heat loss in that room and stay at that temperature. The rads do not get hot and cold as the boiler cuts in and out, but rather maintain an even temperature.
All the same sircosm I think the unvented cylinder will give you more hot water for an equivalent volume that a TS holds.
Putting the buffer section aside.
Re balancing it's not just to keep the return to the boiler cool enough, it's also to provide the most responsive heating system for the energy used by the pump. If you have an unbalanced system the further radiators will be slow to heat up and will have lower output.
Also the benefits you descbee about not yoyo, you can just use a weather compensating system which will keep the flow temperature low.
Yes boilers have minimum cycle time but if you configure the pump to stay on, the water in the system will provide the buffer. With your thermal store you'd have to have a pump running all the time anyway.
The reasonable man adapts himself to the world:
Be reasonable sirocosm and embrace unvented cylinders.![]()
sounds like you already made your mind up and I can see your message about adapting the world to yourself!
But the reality of the world is given the cost conscious customers, simple is whack a (cheap in many cases) one box combi on the wall, get paid, on to the next job. With the cost of labour piping up cylinders and stores is not an easy choice for the vast majority of people and their wallet. You think permanently on system and running rads at 60c with TRVs is simpler, weather compensation thinks that running the rads at the minimum temperature for the heatloss is more efficient. A lot of people think wood burners are simpler. Each to their own.
But if you're doing it yourself you can go all in, and make whatever you feel is most effective.![]()
Top tip for those not in the know, if you're aware your opinion is at odds with most other people's, it might be worth prefixing your posts with "In my personal opinion" to avoid rubbishing everyone else's views
If you think an unvented is better than a thermal store,
