When fitting a new radiator, I assume that I first start my centralising the radiator on the wall, screw brackets and hang radiator.
As a next step, I need to determine exactly where the tail pipes hit the floor board so I can drill the floor and connect these to the flow and return under the floor board.
Q. How do I determine exactly where to drill this floor board hole as the tail pipe is only around 20cm long (above floor), I cant get a level on this, to mark an appropriate point on the floorboard?
I hope that makes sense. Thanks in advance.
