- Joined
- 11 Jan 2004
- Messages
- 43,579
- Reaction score
- 2,801
- Country
Coming across some surprising and interesting stuff.
Window frames, door locks........hooks, brackets, and cleats, clips, saddles and clamps for fixing cables and conduits, need not be connected to the bonding conductor.
Rather the opposite of the bond-mad 15th Edition 40+ years later!
Re Bathrooms:
Wherever practicable, all metal parts of the electrical equipment (other than current-carrying parts) shall be either completely shielded by insulating material or concealed within the walls, floor or ceiling.
Where this is impracticable, the metal parts referred to above shall be permanently and substantially bonded by means of a securely fixed special conductor to other exposed fixed metalwork in the room. This not only includes water pipes and the bath itself (if of metal) but also any exposed gas-pipes.
The bonding conductor may also be used, if desired, as the earth continuity conductor, but a gas-pipe must not be utilised as the earth electrode or earth continuity conductor.
The earthing terminal of every socket-outlet in the room shall be permanently and substantially connected to the special bonding conductor.
The bonding conductor shall consist of either a tinned-copper strip not less than 0.5 inch by 0.02 inch or a stranded tinned-copper conductor not less than 7/.036 inch, which stranded conductor shall be suitably protected from corrosion and mechanical damage.
Given that 7/.036 is bigger than 4 milli, I'm surprised about the requirement for protection from mechanical damage.
Note: The armouring of cables cannot in all cases be relied upon for the purpose of earthing.
1005 (E). The electrical resistance of the earth continuity conductor, including metal conduits, the metal sheathing of cables (other than those used in earth concentric wiring), and the armouring (where an armoured cable has no other metal sheath), together with the resistance of the earthing lead, but excluding the resistance of the earth-leakage circuit-breaker (if any), shall, when measured from the connection with the earth electrode to any other position in the completed installation, not exceed 1 Ohm.
So, there were ELCB's in '39. Didn't know that. And any earth reading must be no more than 1 Ohm. Never mind the extremely long-winded sentence.
1006. .......earth leakage protection........shall be capable of disconnecting the live conductors of the whole installation or, if desired, of only the faulty circuit (or circuits) when the potential between the metal to be protected and earth exceeds 40 volts.
Such earth-leakage protection shall be in the form of one or more automatic devices operating on the existence of a potential between the metal to be protected and earth, or, alternatively, equivalent devices responsive to leakage currents between such metal and earth.
Such automatic devices may, if desired, be incorporated with excess-current protective devices.
Early RCBO's?
1007 (A). Where a water pipe is used as an earth electrode the connection of the earthing lead to such pipe shall be made at the point of entry of the water service into the building.
If this is not convenient, the earthing lead may be connected to the pipe at any other desired position, provided that the pipe has only metal-to-metal screwed, compression or wiped joints, or metal-to-metal bolted flanges (or equivalent), and the resistance measured between any two points of the current-carrying portion of the pipe is such that the potential difference between them cannot exceed 40 volts under fault conditions.
Flexibility about where to attach the conductor to the pipe.
1102. When an insulation test to earth is made of the wiring only (ie before the fittings and switches are fixed) all conductors shall be so connected together as to ensure that all parts of every circuit are simultaneously tested and the insulation resistance to earth shall not be less than 100 megohms divided by the number of outlets.
A new one on me!
The guide then prints the following:
Re Bathrooms:
Early RCBO's?
A new one on me!
