Well, it's up to you to find what makes more sense.Proof indeed that any question you ask on the Internet will often result in conflicting answers
I wasn't having a pop, your answer makes perfect sense, I prefer the 1mm spacer gap to allow for decorating skirting.Well, it's up to you to find what makes more sense.
If the laminate has been fitted correctly, it would have an underlay which covers for any movement.
Installing the skirting 1mm away from the floor would be a real mission, considering that I never, ever found a perfectly straight floor, so naturally there will be gaps under the skirting, sometimes even 5mm.
Even with a pool table levelled floor, there would be no need to waste time on a 1mm gap.
Have a look at online videos for the basics, then if you need more help, come back here and start a thread.I will soon be putting laminate down myself, for the first time. I assume you fill the gap with silicon or something?
And how close to the wall should the laminate go? If skirting is 2cm, do you stop about 1cm from the wall?
