Changing to Smart Switch - Two way switching + No Neutral
10 Jul 2016
Hello Everyone,
I hope someone out there can help please.
Basically I have two way switching for my top landing light which can be controlled from the switch downstairs, and can be controlled from upstairs. The switch has become ancient and I have managed to change all my switches upstairs and downstairs to smart switches (RF) except for these two way switched ones as I'm unsure how to wire it up as its in bit of a mess already.
I say mess, because I can't for the life of me find a diagram that matches my two way system against ones online, each switch only has single wires connected, and upstairs seems to have an issue of not having a permanent live by the looks of things so I'm not sure how would I go about wiring a smart switch in? Its Lightwave so no neutral required, it just shows it needs a live wire, signal wire (low voltage), and switched live so how would I go about doing this. I'm dreading the the thought of having to get the switches rewired if I wanted smart switching so any alternative advice would be appreciated.
I've taken off the switches from the wall and they are wired in this configuration
View media item 105668Downstairs Switch (Correct Way Up)
COM - 1 Red Wire
L1 - 1 Black Wire with red sleeving (Switched i'm guessing)
L2 - 1 Red Wire
View media item 105669Upstairs Switch (Mounted Wrong Way Up)
COM - 1 Red Wire
L2 - 1 Red Wire
Even though upstairs mounted the wrong way up, here's how its working at the moment:
If both switches are up, the lights are off
If one switch is up, other is down, the lights are on
If both switches are down, the lights are off
For the purpose of diagnosing, this is what happens in terms of the wiring being on/off:
[DOWNSTAIRS SWITCH]
If the downstairs switch is "up-off" and upstairs switch is "up-off" (remembering its the opp way mounted)
Then
COM - LIVE
L2 - LIVE
L1 - OFF (Black Wire/Red Sleeved switched)
If the downstairs switch is "down-on" and upstairs switch is "down-on" (remembering its the opp way mounted)
Then
COM - LIVE
L2 - OFF
L1 - ON (Black Wire/Red Sleeved switched)
If the downstairs switch is "up-off" and upstairs switch is "down-on" (remembering its the opp way mounted)
Then
COM - LIVE
L2 - LIVE
[UPSTAIRS SWITCH]
Then
COM - OFF
L2 - LIVE
Then
COM - OFF
L2 - OFF
Then
COM - LIVE
L2 - LIVE
I would really appreciate the help.
Here's a picture of the upstairs ceiling light wiring if this helps too
View media item 105670
Regards,
Jake
COM - 1 Red Wire
L2 - 1 Red Wire
COM - 1 Red Wire
L2 - 1 Red Wire
Your description indicates that somewhere there is a junction box, that you need to locate. Try the loft, but most common place would be 1st floor landing under the floor.
Edit - Also look behind the light fittings
Edit - my comment is incorrect, because I had not seen the photos, that clearly show t&e and s&e, apologies to the OP.
The live and switch wire will normally behind the light fittings.
Hi sparxxxx & EFLImpudence,
Thanks for your advice and help,
So the question is, whats the best way of sorting this out in my situation so I can swap these to smart switches/dimmers?
If I find the juction box, would I need to alter the way its connected? or is there something simple that can be done to get them working?
I'm guessing it will involve swapping cables to bring a live permanent feed to the switch? or would it need rewiring?
I've also attached the upstairs light fitting wiring, just the usual cables so I'll try to dig out and find the junction box tommorow.
Regards,
Jake
Look at EFL's sketch, you only have a live at one switch, and you don't have neutral's at either switch. The wiring could be altered to give a permanent live and permanent switchline at each switch, imagine the switch blades shown as a permanent connections. Your smart switches would connect the two together and as long as the switches can control each other it will work.
So the question is can your switches, control each other ie can one switch turn the other one OFF and vice versa.
