- Joined
- 8 Feb 2021
- Messages
- 15
- Reaction score
- 0
- Country
Hi all.
Newly signed up to this forum, but have searched extensively for information on this one.
Logic Max combi 30
8 radiators, all nice & balanced with around 10-12 degrees drop
3 rads are vertical ‘designer’ style.
All rads have TRVs, don’t have a ‘bypass’
Problem:
(1) I can’t get the boiler to condense due to the return and flow temp (read from directly at the boiler menu screen) being more or less equal. Flow 75 return 65 (10 delta). At times the difference is sometimes less than 5 degrees.
(2) the designer rad in the bedroom clicks and bangs when heating first starts. TRVs and L/S are installed in a mixed fashion, but all are bi-directional.
problem solving so far:
Perfectly balanced all rads. All rads run hot no air.
Removed small amount of air from b/room towel rad
Adjusted boiler flow temp up & down
Adjusted pump speed up & down - choice of 70% or 100% only it seems ?
All TRVs removed, pins move freely, and replaced.
Tied down all pipes, no sides in pipes rubbing furniture or joists.
Side note. my thoughts so far from research: radiators not well sized enough. Air lock causing the banging. Not having a ‘bypass radiator’. Banging noise could be from a faulty TRV? TRV and Lockshield the wrong way around on some rads (unlikely). Pump speed is too high, it’s returning too hot to the boiler.
my main priority is to stop the banging noise in the bedroom and it’s driving me mad.
my heating engineer balanced the system according to his ‘all lock shields kept fully open and use the TRV to control temp’. I wonder if I should return to this method. I’m hesitant to as I’ve just got all rads well balanced.
any ideas?
Logic Max combi 30
Problem:
any ideas?
