- Joined
- 5 Nov 2010
- Messages
- 387
- Reaction score
- 3
- Country
My friend's new build house does not have an outside tap in her rear garden.
She now has an outside tap at the front of the house below her kitchen (photo taken before the installation) window.
Rather than the rigmarole of navigating a long garden hose along the side of the house, between the cars and over the wall (she won't run it through the house) I'm wondering if it's feasible to run a permanent black plastic pipe along the walls that is connected to this tap, bore a hole through the rear garden wall and fit another tap?
If possible, what type of black pipe do I use and can (should) I use solvent weld instead of push fittings? I think a valve outlet is needed near the front garden to drain the water when winter approaches.
This is also putting aside any restrictions the property developers may have in place to prevent such installations!
