- Joined
- 8 Feb 2021
- Messages
- 15
- Reaction score
- 1
- Country
I'm trying to change a leaky isolating valve in the 1st floor bathroom basin, but I can't drive the hot water pressure to zero, and therefore can't remove the valve.
I have a combi boiler in the vault, a hot water cylinder in the cupboard, and a water storage tank on the roof.
I closed the "Hot water to house" valve in the cupboard, and the hot water recycle pump valves on the cylinder. Nope, still water pressure on 1st floor bath.
I closed every valve on roof storage tank, including "to cylinder red", which I assume supplies pressure to the cylinder. Nope, still hot water pressure on 1st floor bath.
I closed the water-main supply valve and turned off the boiler. Nope, still hot water pressure on 1st floor bath.
I closed every visible valve in the entire system: everything. Cold water goes to zero, but still hot water pressure on 1st floor bath.
I have suspected that the plumbing in this house was not engineered correctly but this is disconcerting.
Any thoughts?
Any thoughts?
