- Joined
- 27 Jan 2008
- Messages
- 23,781
- Reaction score
- 2,683
- Location
- Country
Can you have a power factor of 1.5? I thought under unity?
ok its only a cheap energenie plug in meter but i never thought it was lyingWith a non zero power factor the VA would be larger than watts.
If the watts is larger than the VA as in this example it is due to lies, nothing more.
thanks it doesnt say the lumins value ??I buy Philips LED lamps where possible as I've found them to be reliable and very decent light output, here is where I get mine from and I've linked directly to a suitable lamp for you:
https://theledspecialist.co.uk/philips-corepro-ledbulb-nd-13-100w-a60-e27-827.html
I bought 16 Philips golf ball CFL for my dinning and living room in the last house, they were rotten, after a year ½ failed and the cheap bulbs from homebargains lasted three times longer, I had always thought Philips were good, but seems no longer, and with G9 the small LED from local shop did allow covers to be fitted, but the cheap internet one did not flash or flicker, so in real terms the cheap one again was far better.I buy Philips LED lamps where possible as I've found them to be reliable and very decent light output, here is where I get mine from and I've linked directly to a suitable lamp for you:
Put the code into google and all the info is on the philips sitethanks it doesnt say the lumins value ??
I've got a (growing!) pile of dead CED branded bulbs, think I bought them 4 years ago. Various other cheap one too. Philips have lasted ok though, they're older.I bought 16 Philips golf ball CFL for my dinning and living room in the last house, they were rotten, after a year ½ failed and the cheap bulbs from homebargains lasted three times longer, I had always thought Philips were good, but seems no longer, and with G9 View attachment 250481 the small LED from local shop did allow covers to be fitted, but the cheap internet one did not flash or flicker, so in real terms the cheap one again was far better.
My son seems to think his GU10 bulbs have failed due to using cheap toolstation bulbs, but also had a LED 5 foot tube fail in same room, so maybe a poor switch causing spikes?
Homebargains and B&M Bargains LED bulbs seem to have lasted well for me.
Today a Smart bulb failed, however so much easier to swap a smart bulb than smart switch, I will still go for smart bulbs not switches in the future.
@big-all has really said it. Does it really matter? Expensive or cheap does no longer seem to relate to good and bad, so you don't want draws or cupboards full of spares, so what ever is sold in the cheap shop near you is what you buy. OK I will buy bulbs from Lidi, but I would not go to Lidi for bulbs as they are not a stock item, so if I want a bulb now I would go to B&M Bargains as they keep bulbs as a stock items and are the nearest cheap shop to me.
Only when local shops can't supply a good bulb will I use internet, as with the G9 bulbs.
Despite the fact that I couldn’t see any mention of lumens in Dannyboi’s link, I’ve decided that I’ll go for the bulbs he suggests.Lumens is the real measure of light - the higher the 'lm' number the more light it produces. Look to see if you can see that number
