Positioning flat roof rafters
23 Jun 2018
I'm installing a flat roof on a single storey extension. I'm installing the first rafter and unsure how far it should be from the adjacent wall that runs parallel. Is there a set distance or does butt up to the internal wall ?
I will be adding insulation in between the rafters so not sure if I need to leave space between the rafter and the wall. See illustration please.
As I'm adding firings there will be a 2inch gap which diminishes to zero between the top of the outer wall and OSB, how is this best filled in ?
Additionally, One end of the rafter will hang from the steel and the other end will rest on the wall, is a wall plate required for a flat roof or can the rafter rest on the brick?
Thanks again
