- Joined
- 27 Jan 2008
- Messages
- 23,765
- Reaction score
- 2,680
- Location
- Country
I would exclude extra low voltage, however I have said before hard-wired boilers, cookers, kitchen/laundry appliances etc. would be not part of any EICR using IET guide lines, so not part of the installation, however the new landlord law quotes "The Electricity Safety, Quality and Continuity Regulations 2002" as giving the definition.
However if I was the person with the silly down lighters I would likely ignore the laws and regulations and replace the extra low voltage units with low voltage units (230 volt GU10) or re-wire so one electronic transformer powers enough lamps so the load exceeds the minimum written on the electronic transformer.
Which would be depending if I could return the extra low voltage bulbs or not.
The advert if you look carefully says
and I would say that is clearly misleading, but if supplied like this although it says
which does seem to say 35 watt although in fact 5 watt, once the packet is opened then they can't be replaced on the shelf, and I could under stand a shop not allowing them to be returned.
So which method is used depends on if the bulbs can be returned.
I apologise for bringing up the legal and regulation arguments, however I felt you needed to be aware there may be a latter problem if the property is rented, the toroidal lighting transformer option would work, but rather expensive. With a GU10 fitting the bulb is changed with a sucker where when a G5.3 fitting is converted it still uses the retaining ring, so harder to change, however we would hope that would not be that often.
so it seems if permanently connected or intended to be permanently connected then it is included in at least the landlord EICR so if not considered as portable and it needs to be moved to reach the plug, then part of the installation. So it seems hard-wired boilers, cookers, kitchen/laundry appliances etc. do come under installation.The Electricity Safety Quality and Continuity Regulations 2002 said:“consumer’s installation” means the electric lines situated upon the consumer’s side of the supply terminals together with any equipment permanently connected or intended to be permanently connected thereto on that side;
