Not by the looks of things!Are you getting this signed off?
Super-insulated block? Send me a brochure.Thats way OTT..... probably be cheaper and less hassle to build it in block
Insulated Cavity wall with a foundation? I think not.Thats way OTT..... probably be cheaper and less hassle to build it in block
It stuck proud by about 5mm. Didn't matter as there was another layer going on top prior to the boards being fixed.Good point Nose. How did u get 100mm PIR into a 4x2 stud wall?
One layer fireline will be fine. We did two and cross jointed because the customer wanted max sound block.Ah, ok makes sense. Thanks again. I've ordered 100mm for between and 50mm over the top. Hoping 1 layer of fireline will suffice on garage side.
Lol. Should have used acoustic board then.One layer fireline will be fine. We did two and cross jointed because the customer wanted max sound block.
