Bed bugs are an advanced pest control problem. Anyone can get rid of mice, but many pest controllers haven't got a clue when it comes to bed bugs. It's extremely difficult to get bed bugs out of a sofa and usually the best option is to throw it out, which is very expensive.
I had bed bugs for years and tried everything, (Steam/hoover/powder/chemicals/two 'professionals'/traps). I finally got rid of bed beds by wrapping my entire sofa in shrink wrap, inserting a hairdryer, topside and underside, and cooking them. At 45 degrees they die in minutes, I did it for 1.5 hours and 50-60 degrees. Remove the black material covering the base so the hot air circulates, and make sure the shrink wrap is air tight.
Afterwards, put bed bug traps under the sofa legs, or wrap flypaper around them.
For the bed frame I toasted every inch of it, inside the steel tubing and out, with a heatgun/paint stripper, the frame is metal but even the wooden slats and plastic bits were only slightly scorched in places, and afterward put traps under the legs or wrap flypaper around them. You can use a hairdryer and shrink wrap on the bed instead if you prefer. Use a blanket not a duvet and tuck it under the mattress so it doesn't touch the floor at night.
If you see the bed bugs you have quite a bad infestation so get a pest controller to spray the place as well. He has to come at least twice to kill the new ones when the eggs hatch in ten days, if he says it only needs one treatment, he's a cowboy.
Shrink wrap is £7 on ebay or amazon, turkey thermometers are £3, and hairdryers are £15, heatguns are £20 -£30.
![No photo description available. No photo description available.](https://scontent-lcy1-1.xx.fbcdn.net/v/t39.30808-6/295800701_1819879638351036_6131551745397320914_n.jpg?stp=dst-jpg_s1080x2048&_nc_cat=110&ccb=1-7&_nc_sid=5cd70e&_nc_ohc=bF3e8tIpXFgAX_Ywzqo&tn=XJTSEvWj_V2L6DFa&_nc_ht=scontent-lcy1-1.xx&oh=00_AT_XOKmGRGDh4DLwrpRCeyiN7c-7TN401UgnhGB6rufwcw&oe=62E76427)
