- Joined
- 24 Aug 2009
- Messages
- 2,663
- Reaction score
- 281
- Country
Hi
I have just started hearing a "clonking " noise from the suspension when driving over poor road surfaces. When I bounced the car to locate the sound, it was clearly from the front left. Jacking up that corner and twisting the wheel didn't give a clear result, but possibly a slight movement compared with the other wheels.
Viewing the different parts didn't show any signs of torn or damaged rubber mounts, and none moved/rattled when shaken, however I did notice a light aerosol of oil ( not a complete film ) on the shock-absorber: this is very light at the moment, no drops and not enough has leaked to leave any traces on the lower retaining plate. The tie-rods were replaced in January for the MOT and the mechanic/tester made no remarks about visible wear on other components.
Oddly I have never had any problems with suspension components before, so have no experience to fall back on.
My questions are:
1) Is what seems to be an early stage of failure sufficient to cause this clonking ? It (clonking ) only started in the last 200 miles .
2) Once a damper starts leaking, how quickly does the leaking usually progress ?
3) The car has done 106 000 miles, so which other related components would you change at the same time ? The dampers are GM components so may well
be original.
4) Would you also do the other damper unit at the same time as is usually recommended ? When I had a broken spring on another Vectra, I only changed one
and noticed no difference/problems. My driving style is fairly relaxed, no high speeds, screeching through corners etc.
5) Any idea of hours required for changing unit, and possibly top/bottom mounts/bearings ?
Look forward to your advice. Thanks
My questions are:
be original.
