Hey google turn on landing lights works for me, far easier than having to walk to light switch by the front door. I think the idea is daft, but do try to present real reasons why it should not be done. To my mind having switched FCU for lights you would still have a light switch in the normal place.If you had table lamps etc plugged into this cct that you propose, to switch a lamp on you would have to navigate a dark room to find the lamp to switch it on rather than the easier " normal" solution of having a switch by the door.
Or a non-switched FCU, and a conventional switch in a conventional place!To my mind having switched FCU for lights you would still have a light switch in the normal place.
The OP's proposal is to have a house with no lights - until someone plugs in some lamps.but do try to present real reasons why it should not be done.
So, you might as well have normal lighting circuits.To my mind having switched FCU for lights you would still have a light switch in the normal place.
Exactly.So big question is why would you want to wire that way?
