- Joined
- 17 Oct 2018
- Messages
- 90
- Reaction score
- 7
- Country
Usual problem - I bought a set of LED downlighters, and a dimmer switch - but the dimmer doesn't reduce the light level!
The dimmer switch is a BG Nexus 200W Grid Dimmer (SKU: RBNDTR) - Trailing Edge.
The LEDs are 6 x 6W flat panel. Neither seller nor product packaging state compatibility regarding dimming.
For comparison, I've tried an old spare dimmer that's marked "Tungsten only" and the effect is flickering.
Q1. Is this likely to be the dimmer type known as Leading Edge? If not, it might be worth buying a Leading Edge dimmer to test.
Q2. Is it a common problem that absolutely no type of dimmer will work?
Q3. In another thread it's mentioned to try adding a Contact Suppressor. Would eBay item https://www.ebay.co.uk/itm/134276575717 be okay, and where would I connect the pins?
Hoping I can avoid changing the LEDs again - it's currently the third pack of ten I've bought, trying to get the brightness and colour temperature spot on..
