RCD Tripping emegency Electrician cannot fix
well, still not sorted, spent 6hrs on it yesterday , taking all the Cu leads off , sockets removed - lights and fans disconnected , they cant get a replacement RCD , but it tests all OK, and then randomly trips - 2 other electricians involved from the team
so now a new consumer unit is going on, New Ring for kitchen and other Rings sorted out ........
i'm sure this is something simple now - maybe a mouse laying in a cable after chewing but should show up on a insulation test , screw in a cable when the refitted the downstairs cloak room and shower - or a faulty RCD - BUT ........
Could it be a bulb on its way out, just a suggestion.
Who knows, but I've never come across a bulb/lamp of any sort behaving in that fashion. In fact, since bulbs/lamps invariably don't have earths, it's very hard to see how one could result in an RCD trip, no matter what was happening within them.
I did talk to him and was not that impressed and he was not really interested in doing anything more ..... having collected £160 ......
I think I would be asking for your £160 back. He seems to think he had 'earned' his £160, simply for turning up at the door. It seems that having turned up, he didn't have the slightest clue how to proceed, so likely a scam tradesman.
yea, but i was just over the phone and not paying the bill - he has been asked to provide a full report and figures for the new electrician
partners son, his father agreed to payit and will not confront him, even though i suggested
When your knocking on a bit its easier to just pay up and avoid any hassle, especially if money is not too tight. He probably feels its just better to move on.
Very true, but, if I understand correctly, we're talking about the OP's partner's son, who presumably cannot be 'getting on' too much (unlikely as much as myself :) ).
Doh! My bad as the young ‘uns say.
Just thought i would update to finish this tread
new consumer unit with spike protection and all RCBO's installed today - and they also found loads of problems with the kitchen wiring, when they took all the sockets off (which they do as part of th einstall - then take all sockets off around the house - and test ) they had to strip out all the kitchen wiring rewire, at least the message and photos sent.
they found 1 socket very badly wired - with exposed cables and poor connections , but none where good in the kitchen....
anyway - all sorted now
Makes you wonder why a meggers exist if you cannot use them to check parts of circuits.....
yep, my thoughts as well, i kept asking what the insulation test results showed - I would have expected a test at 500v should have solved - But anyway its all resolved - hopefully
