Help! New WiFi/RF thermostat wiring
There is a brown (with black under), yellow/green, blue (with grey under) and just brown.
So there is a grey, 3 core and earth cable, coming out of the FCU, and connecting to the thermostat - this would explain the use of sleeving.
We could do with seeing a picture of the wiring behind the FCU to confirm the connections - this would be best done with the circuit off at your consumer unit.
...although I'm still going with my original guess! ;)
Blue to Neutral
Brown to Live
A small link wire between Live and Com
Black with brown sleeve to Open
And safely park the earth.
  • Thanks
Reactions: CBW
Not the easiest angle to take pictures but hopefully this shows.
The grey and the brown covered black connect to a black and a brown.
Appears so, yes
Ok, then:
Blue to Neutral
Brown to Live
Or very specifically,
Grey covered with Blue sleeving connects to N on new stat
Brown to L
Add a short link wire, from the same L terminal on the new stat, to the 'Com' terminal
Black covered with brown sleeving to 'Open' terminal
Safely park the yellow/green earth wire in a terminal block out of the way.
and let us know if that works...
Ok, then:
Brown to L
Yay that appears to be working. Thank you all for the help.
